Skip to main content
Electron Internals: Using Node as a Library
· 5 min read
This is the second post in an ongoing series explaining the internals of Electron. Check out the first post about event loop integration if you haven't already.
Most people use Node for server-side applications, but because of Node's rich API set and thriving community, it is also a great fit for an embedded library. This post explains how Node is used as a library in Electron.
Build system
Both Node and Electron use GYP as their build systems. If you want to embed Node inside your app, you have to use it as your build system too.
New to GYP? Read this guide before you continue further in this post.
Node's flags
The node.gyp file in Node's source code directory describes how Node is built, along with lots of GYP variables controlling which parts of Node are enabled and whether to open certain configurations.
To change the build flags, you need to set the variables in the .gypi file of your project. The configure script in Node can generate some common configurations for you, for example running ./configure --shared will generate a config.gypi with variables instructing Node to be built as a shared library.
Electron does not use the configure script since it has its own build scripts. The configurations for Node are defined in the common.gypi file in Electron's root source code directory.
In Electron, Node is being linked as a shared library by setting the GYP variable node_shared to true, so Node's build type will be changed from executable to shared_library, and the source code containing the Node's main entry point will not be compiled.
Since Electron uses the V8 library shipped with Chromium, the V8 library included in Node's source code is not used. This is done by setting both node_use_v8_platform and node_use_bundled_v8 to false.
Shared library or static library
When linking with Node, there are two options: you can either build Node as a static library and include it in the final executable, or you can build it as a shared library and ship it alongside the final executable.
In Electron, Node was built as a static library for a long time. This made the build simple, enabled the best compiler optimizations, and allowed Electron to be distributed without an extra node.dll file.
However, this changed after Chrome switched to use BoringSSL. BoringSSL is a fork of OpenSSL that removes several unused APIs and changes many existing interfaces. Because Node still uses OpenSSL, the compiler would generate numerous linking errors due to conflicting symbols if they were linked together.
Electron couldn't use BoringSSL in Node, or use OpenSSL in Chromium, so the only option was to switch to building Node as a shared library, and hide the BoringSSL and OpenSSL symbols in the components of each.
This change brought Electron some positive side effects. Before this change, you could not rename the executable file of Electron on Windows if you used native modules because the name of the executable was hard coded in the import library. After Node was built as a shared library, this limitation was gone because all native modules were linked to node.dll, whose name didn't need to be changed.
Supporting native modules
Native modules in Node work by defining an entry function for Node to load, and then searching the symbols of V8 and libuv from Node. This is a bit troublesome for embedders because by default the symbols of V8 and libuv are hidden when building Node as a library and native modules will fail to load because they cannot find the symbols.
So in order to make native modules work, the V8 and libuv symbols were exposed in Electron. For V8 this is done by forcing all symbols in Chromium's configuration file to be exposed. For libuv, it is achieved by setting the BUILDING_UV_SHARED=1 definition.
Starting Node in your app
After all the work of building and linking with Node, the final step is to run Node in your app.
Node doesn't provide many public APIs for embedding itself into other apps. Usually, you can just call node::Start and node::Init to start a new instance of Node. However, if you are building a complex app based on Node, you have to use APIs like node::CreateEnvironment to precisely control every step.
In Electron, Node is started in two modes: the standalone mode that runs in the main process, which is similar to official Node binaries, and the embedded mode which inserts Node APIs into web pages. The details of this will be explained in a future post.
